メインコンテンツにスキップ
How to easily fix a Xbox 360 drive that wont open.
必要な工具と部品
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: 手順 1、 2の画像 1 How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: 手順 1、 2の画像 2
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: 手順 2、 1の画像 1
    • Use a paper clip or a long pick tool to manually open DVD Drive.
  3. How to easily fix a Xbox 360 drive that wont open.: 手順 3、 2の画像 1 How to easily fix a Xbox 360 drive that wont open.: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: 手順 4、 2の画像 1 How to easily fix a Xbox 360 drive that wont open.: 手順 4、 2の画像 2
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: 手順 5、 1の画像 1
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
  6. How to easily fix a Xbox 360 drive that wont open.: 手順 6、 2の画像 1 How to easily fix a Xbox 360 drive that wont open.: 手順 6、 2の画像 2
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
終わりに
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
15 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Matt Weatherly
メンバー登録日: 09/16/12
1,305 ポイント
2のガイドは作成済み
8 件のコメント
the picture of the exbox is not mine
dongwillows - 返信
the picture you show is not my console
dongwillows - 返信
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - 返信
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Gustavo Montes - 返信
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 20
過去 30 日: 108
今までの合計 11,206
