メインコンテンツにスキップ
How to downgrade iPhone 4S / iPad 2 to iOS 6.1.3
  1. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Enter kDFU mode: 手順 1、 1の画像 1
    • Launch Cydia and add repo: http://repo.tihmstar.net to enter KDFU mode (Please check the detailed tutorial). Only when your iDevice is in KDFU mode, you can downgrade to iOS 6.1.3. Please make sure your iDevice is in KDFU mode, then continue to downgrade.
  2. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Download custom firmware.: 手順 2、 1の画像 1
  3. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, 3uTools proflash: 手順 3、 1の画像 1
    • Launch 3uTools and go to “Flash & JB” -> “Pro Flash”, click “Import Firmware” and select the firmware you have already downgraded.
  4. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Go "Flash": 手順 4、 1の画像 1
    • After you import the firmware, click “Flash” on the right bar.
  5. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Wait till the process is finished: 手順 5、 2の画像 1 How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Wait till the process is finished: 手順 5、 2の画像 2
    • Now 3uTools will automatically flash your iDevice, please confirm the connection between your iDevice and pc.
  6. How to downgrade iPhone 4S / iPad 2  to iOS 6.1.3, Finish: 手順 6、 1の画像 1
    • Normally, it would take around 10 minutes to downgrade.
終わりに
21 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Grace
メンバー登録日: 02/09/17
1,696 ポイント
1ガイドが承認済み
10 件のコメント
Great guide! I haven’t tried it out yet, but it looks great!
Naples - 返信
Thanks this worked perfectly!
Joseph - 返信
This is a very poor guide, well below IfixIt standards. Perhaps experienced hackers might follow these steps
but if I was a hacker would I need this. Which Cydia,? Where to download? Download it onto the target device or a laptop connected to
the target device. C’mon guys this is seriously sloppy work.
kevin hunter - 返信
firstly you need to know how to upgrade your device to 9.3.5 for iphone 4s only, you can follow apples’s guide. then you need to jailbreak it a quick google search will lead you to a fast guide on how to jailbreak it. then come back here to follow the instructions on how to to downgrade it to 6.1.3. just use google people <3
WOLFRANDMAC Is On -
This guide is not intended towards the average person. If you are interested in completed what is done here, you should research more into this, using other sites. Once you can get the hang of it, im sure you’ll love it. (But to answer your question, The Cydia you want to use is the one downloaded on your phone after a jailbreak, and download the firmware onto your computer)
imblocko -
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 124
過去 30 日: 668
今までの合計 45,838
