メインコンテンツにスキップ
How to diagnose Samsung Galaxy A40 Charging Problems
ビデオの概要
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 手順 1、 3の画像 1 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 手順 1、 3の画像 2 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 手順 1、 3の画像 3
    • This is the +5V line from the Charging port to the Motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 手順 2、 3の画像 1 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 手順 2、 3の画像 2 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 手順 2、 3の画像 3
    • Warm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 手順 3、 3の画像 1 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 手順 3、 3の画像 2 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 手順 3、 3の画像 3
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 手順 4、 3の画像 1 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 手順 4、 3の画像 2 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 手順 4、 3の画像 3
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 手順 5、 3の画像 1 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 手順 5、 3の画像 2 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 手順 5、 3の画像 3
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: 手順 6、 3の画像 1 How to diagnose Samsung Galaxy A40 Charging Problems: 手順 6、 3の画像 2 How to diagnose Samsung Galaxy A40 Charging Problems: 手順 6、 3の画像 3
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
終わりに
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
194,072 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
327 メンバー
1,697のガイドは作成済み
コメント 1 件
How to fix samsung A50s with termometer logo on screen when charging
Den Bagoese - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 44
過去 30 日: 176
今までの合計 10,274
