メインコンテンツにスキップ
How to create a ChromeOS Recovery USB Drive
必要な工具と部品
    • In order to make your recovery device, you will need the following items.
    • 1 x USB Drive or SD Card (8 GB is the minimum)
    • Any content that is stored on this drive will be erased during the next few steps. Be sure to back up any content you want saved, or make sure this is a drive you are going to use for future devices.
    • 1 x computer running the Google Chrome Browser, or Chrome OS.
  1. How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: 手順 2、 2の画像 1 How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: 手順 2、 2の画像 2
    • Open Google Chrome and navigate to the Chrome Web Store and download the Chromebook Recovery Utility extension.
    • Add the utility to Chrome and launch it. You will be greeted with this page.
  2. How to create a ChromeOS Recovery USB Drive, Enter your Chromebook Model Number: 手順 3、 1の画像 1
    • Click on "Get started" and you will be prompted to enter the model of your Chromebook.
    • You have the option of either entering the code that is on the device's recovery screen, or choosing from the model list.
  3. How to create a ChromeOS Recovery USB Drive, Insert your Removable Media: 手順 4、 1の画像 1
    • Plug in your spare 8 GB USB Drive and select it from the dropdown menu.
    • Any content that is stored on the drive will be erased during the next few steps. Make sure that the drive is empty, or does not have any data that you don't want to lose.
  4. How to create a ChromeOS Recovery USB Drive, Create Recovery Image: 手順 5、 1の画像 1
    • You will be presented with a screen that shows the drive you selected. Click on the "Create now" button and the processes will begin.
    • Do not remove the drive while the process is taking place. The process will take about 5 minutes to complete and you will be prompted when the recovery drive is finished.
終わりに
If you intend on reusing the drive for storing files you will need to use the Recover Utility application to erase the data on the drive, and you will need to reformat it with a recovery tool.
87 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jacob Mehnert
メンバー登録日: 10/18/21
44,184 ポイント
51のガイドは作成済み
チーム
iFanatics iFanatics人のメンバー
Community
63 メンバー
218のガイドは作成済み
15件のガイドコメント
Thanks only this is working all the other instructions on google didnt work… Direct and simple instructions
idide akeh - 返信
I'm glad to hear that this guide helped you out!
Jacob Mehnert -
Hello....I followed all you said here yet my USB flash drives got corrupted after the recovery utility completed
Amos - 返信
Hello, you might need to wipe the USB drive and attempt to install the recovery tool again. You might also want to check that the drive is formatted to FAT32. Other formats have been known to cause errors with the recovery tool.
Jacob Mehnert -
Does it matter if it’s a 2.0 or 3.0 USB drive???
Josh Knapp - 返信
コメントを追加
統計データ:
過去 24時間: 57
過去 7 日: 294
過去 30 日: 1,391
今までの合計 50,303
