必要な工具と部品
Go to https://www.samsung.com/levant/support/k... , download and install the program.
From the main menu, go to Settings,
Then select the 8th option "PC connections",
Finally, select the option "Samsung Kies".
While the phone is connecting, you will see this screen.
Lastly, you have finally connected your phone successfully to your PC! Explore your options via Samsung Kies!
もう少しです!
Close to program and disconnect your device.
終わりに
ある他の人がこのガイドを完成しました。
