はじめに
This guide will walk you through the steps to cleaning the Roomba air filter. A clean filter will improve performance and should be checked regularly.
  1. Slide out back bin by pressing the unmarked button on top of the Roomba.
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. Slide out yellow bar on particle bin to access filter
    • Slide out yellow bar on particle bin to access filter
    • This is the air filter assembly
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
    • Reassemble the air filter assembly and slide the particle bin back into place
まとめ
3 の人々がこのガイドを完成させました。
Scott Leonard
メンバー登録日: 2010年10月05日
439 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 20-6, Maness Fall 2010 Cal Poly, Team 20-6, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S20G6
2 メンバー
3のガイドは作成済み
コメント1件
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 4,690
