メインコンテンツにスキップ
How to clean the Sega Genesis game port
必要な工具と部品
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: 手順 1、 1の画像 1
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: 手順 2、 1の画像 1
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: 手順 3、 1の画像 1
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: 手順 4、 1の画像 1
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
ゴール
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Erik Bjornstrom
メンバー登録日: 10/04/10
829 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S3G29
4 メンバー
14のガイドは作成済み
4 件のコメント
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - 返信
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - 返信
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - 返信
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 30
過去 30 日: 164
今までの合計 36,397
