メインコンテンツにスキップ
How to clean the Samsung SGH-E317 keypad
必要な工具と部品
  1. How to clean the Samsung SGH-E317 keypad, Battery: 手順 1、 1の画像 1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. How to clean the Samsung SGH-E317 keypad, Motherboard: 手順 2、 1の画像 1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. How to clean the Samsung SGH-E317 keypad: 手順 3、 1の画像 1
    • Remove the rubber screw cover using your fingernail.
  4. How to clean the Samsung SGH-E317 keypad: 手順 4、 1の画像 1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. How to clean the Samsung SGH-E317 keypad: 手順 5、 1の画像 1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. How to clean the Samsung SGH-E317 keypad: 手順 6、 1の画像 1
    • With the back panel removed, the motherboard should be fully exposed.
  7. How to clean the Samsung SGH-E317 keypad: 手順 7、 2の画像 1 How to clean the Samsung SGH-E317 keypad: 手順 7、 2の画像 2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. How to clean the Samsung SGH-E317 keypad: 手順 8、 2の画像 1 How to clean the Samsung SGH-E317 keypad: 手順 8、 2の画像 2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. How to clean the Samsung SGH-E317 keypad: 手順 9、 2の画像 1 How to clean the Samsung SGH-E317 keypad: 手順 9、 2の画像 2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  10. How to clean the Samsung SGH-E317 keypad, How to clean the Samsung SGH-E317 keypad: 手順 10、 1の画像 1
    • After removing motherboard, the phone will look like this.
  11. How to clean the Samsung SGH-E317 keypad: 手順 11、 1の画像 1
    • Grab the corner of the rubber key pad and lift out slowly.
  12. How to clean the Samsung SGH-E317 keypad: 手順 12、 2の画像 1 How to clean the Samsung SGH-E317 keypad: 手順 12、 2の画像 2
    • By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Joe Cavaletto
メンバー登録日: 01/30/11
101 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-23, Maness Winter 2011 Cal Poly, Team 11-23, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G23
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 947
