Use a small prying device to delicately separate the front casing from the back.
New line.
When separating the 2 cases be cautious of the silver band and buttons that located in the middle of the camera. They will come loose.
Remove the 2 screws on the right side of the camera.
Remove the 2 screwson the left side of the camera
CAUTION! Circuit ribbon is attached at the top left of the camera be careful when separating the front and back of the camera after removing the 4 screws.
You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
Using a size 0 Phillips head, remove 3 screws holding the ribbon cable that covers the back of the lens.
CAUTION: small loose pieces under the back lens cover
Using tweezers remove tiny square lens cases. There are 4 small pieces.
The pieces are relatively small, so becareful that they do not fall inside of the lens.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
