メインコンテンツにスキップ
How to clean the Olympus Stylus 760 lens and sensor
必要な工具と部品
  1. How to clean the Olympus Stylus 760 lens and sensor, How to clean the Olympus Stylus 760 lens and sensor: 手順 1、 1の画像 1
  2. How to clean the Olympus Stylus 760 lens and sensor: 手順 2、 1の画像 1
    • Remove the screw located on the right side of the camera
  3. How to clean the Olympus Stylus 760 lens and sensor: 手順 3、 1の画像 1
    • Remove the two screws from the left side of the camera
  4. How to clean the Olympus Stylus 760 lens and sensor, Separation: 手順 4、 1の画像 1
    • Use a small prying device to delicately separate the front casing from the back.
New line.
    • When separating the 2 cases be cautious of the silver band and buttons that located in the middle of the camera. They will come loose.
  5. How to clean the Olympus Stylus 760 lens and sensor: 手順 5、 3の画像 1 How to clean the Olympus Stylus 760 lens and sensor: 手順 5、 3の画像 2 How to clean the Olympus Stylus 760 lens and sensor: 手順 5、 3の画像 3
    • Remove the 2 screws on the right side of the camera.
    • Remove the 2 screwson the left side of the camera
    • CAUTION! Circuit ribbon is attached at the top left of the camera be careful when separating the front and back of the camera after removing the 4 screws.
  6. How to clean the Olympus Stylus 760 lens and sensor: 手順 6、 1の画像 1
    • Carefully flip up the clip attaching the ribbon from the rear to the front and pull it out
  7. How to clean the Olympus Stylus 760 lens and sensor: 手順 7、 1の画像 1
    • Carefully separate the front and back of the camera
  8. How to clean the Olympus Stylus 760 lens and sensor: 手順 8、 1の画像 1
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  9. How to clean the Olympus Stylus 760 lens and sensor: 手順 9、 1の画像 1
    • Using a size 0 Phillips head, remove 3 screws holding the ribbon cable that covers the back of the lens.
    • CAUTION: small loose pieces under the back lens cover
  10. How to clean the Olympus Stylus 760 lens and sensor: 手順 10、 1の画像 1
    • Using tweezers remove tiny square lens cases. There are 4 small pieces.
    • The pieces are relatively small, so becareful that they do not fall inside of the lens.
  11. How to clean the Olympus Stylus 760 lens and sensor: 手順 11、 1の画像 1
    • Remove the larger black rubber frame. Clean with condensed air.
終わりに
作成者
5人の作成者と共同で作成されました。
Derek Guzman
メンバー登録日: 02/10/12
17 ポイント
1ガイドが承認済み
チーム
James Madison, Team 3-3, Klein Spring 2012 James Madison, Team 3-3, Klein Spring 2012人のメンバー
JMU-KLEIN-S12S3G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 1,993
