メインコンテンツにスキップ
How to clean the Nintendo 64 cartridge slot
必要な工具と部品
  1. How to clean the Nintendo 64 cartridge slot, How to clean the Nintendo 64 cartridge slot: 手順 1、 1の画像 1
    • Open the slot with your finger. Blow along the length of the cartridge slot with the air duster.
  2. How to clean the Nintendo 64 cartridge slot: 手順 2、 1の画像 1
    • Moist a q-tip with rubbing alcohol. Rub it along the length of the cartridge slot.
終わりに
If cleaning the cartridge slot worked, you should be able to insert a game and play normally. If the game still does not boot normally, check to make sure the pins are not damaged, and that the cartridge does not need cleaning.
27 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
tonymag28
メンバー登録日: 10/28/09
2,154 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009人のメンバー
CPSU-REGAN-F09S5G4
7 メンバー
15のガイドは作成済み
11 件のコメント
Oh, my God! I really didn't think the alcohol thing would work (actually, I thought it was going to scr#w my nintendo), but it did! Thank u so much!
silvestrerenata - 返信
I'm a Iittle skeptic to use rubbing alcohol on my N64 system and games are you 100% sure it works and won't give me any problems downs the road.
James Hernandez -
You should use isopropyl alcohol, it’s 90% alcohol and drys very quickly. I usually dunk a q-tip in, tap it against the bottle to remove any excess, then clean the surface. As long as your not pouring the alcohol directly onto your electronics you’ll be fine.
Adam -
This works because water and other liquids contain minerals that are conductive, thus, by having it on a running electronic device, it will cause a malfunction/short, whatever you call it, HOWEVER, if the device is off, no electricity is flowing, thus the rubbing alcohol does what you want it to, and removes all the dirt and grime preventing your games from playing..
Bloxy -
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 88
過去 30 日: 390
今までの合計 80,541
