メインコンテンツにスキップ
How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers
必要な工具と部品
  1. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Back Panel: 手順 1、 1の画像 1
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Inner Back Pannel: 手順 2、 2の画像 1 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Inner Back Pannel: 手順 2、 2の画像 2
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Upper Portion: 手順 3、 2の画像 1 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Upper Portion: 手順 3、 2の画像 2
    • Press down on the two plastic hinges to remove the upper portion of printer.
  4. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Unplug Speaker Wire: 手順 4、 1の画像 1
    • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
  5. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray: 手順 5、 2の画像 1 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray: 手順 5、 2の画像 2
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward to release the tabs from the printer.
  6. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray - cont.: 手順 6、 1の画像 1
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
  7. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 手順 7、 1の画像 1
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  8. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 手順 8、 1の画像 1
    • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  9. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Detaching the Scanner Tray: 手順 9、 1の画像 1
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
  10. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 手順 10、 1の画像 1
    • Using the T10 Torx Security Bit Screwdriver, remove the four black screws holding the printer carriage cover in place.
  11. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 手順 11、 1の画像 1
    • Depress plastic tabs to release the cover from the sides.
    • There is nothing holding the left side panel in place, so pull it away from the printer body.
  12. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: 手順 12、 1の画像 1
    • Turn the smallest white plastic gear on the left side of the printer to rotate feed rollers.
  13. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Clean Rollers: 手順 13、 1の画像 1
    • While rotating the feed rollers, clean them with purified or distilled water and a lint-free cloth.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Cody Long
メンバー登録日: 04/12/11
153 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-31, Maness Spring 2011 Cal Poly, Team 12-31, Maness Spring 2011人のメンバー
CPSU-MANESS-S11S12G31
5 メンバー
9のガイドは作成済み
コメント 1 件
Nice instructions, but there's nothing here about the video card readers on the right front. Can't get the right-side panel off. Otherwise, the instructions are well displayed.
Gayle Bryan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 12,008
