はじめに
This guide will show you an effective way of cleaning the Apple Magic Mouse 2. This guide does not include a tear down of the device to clean it but shows how to clean the outside of the mouse itself.
NOTE: Canned air is optional but is recommended for this guide.
必要な工具と部品
この手順で使用する道具:Microfiber Cleaning Cloths$3.99
Using a soft or microfiber cloth, rub on the glass, laser sensor, and the metal portion of the mouse to remove any dust or smudges.
After doing a dry wipe off the outside of the mouse, it is recommended to use isopropyl alcohol to sanitize the mouse. Water can be used as a cleaning alternative too.
Dirt and debris can build up in the charging port and in between the rubber and the mouse. Constant cleaning can ensure the mouse stays clean and functions well.
Using your spudger tool, carefully move the spudger in the grooves of the mouse and rubber. This will help to remove and loosen any debris.
Using the flat edge of the spudger, carefully move it around the lightning port to loosen any debris.
7 の人々がこのガイドを完成させました。
