はじめに
The screen on my nexus gets wet, it was just the screen (i was running and it entered sweat) which caused it began to marked by itself, the first day was just a few minutes and then ceased, but in recent days it became very annoying, mark everything like crazy just was unlocked.
The second week after the release of Android lolipop reach my nexus update; had the update but could not use the phone and the new screen come otherwise within three weeks or so (I'm outside the US) so I could not wait.
必要な工具と部品
In this video you can see the damage; the screen has lost touch sensitivity in the areas that are blank in this drawing program.
この手順で使用する道具:Heat Gun$24.99
Flex what needs to be unstick
The first layer we need remove.
The second layer still on the frame of the screen.
The wet layers are on the screen
use the guitar pick to separate the layers
2nd layer
3rd layer
3rd layer - don't separate.
4th layer - don't separate.
5th layer don't remove.
I cleaned all the layers perfectly with electronic contact cleaner.
Once you have cleaned and dried the layers you must reassemble in reverse order.
19 の人々がこのガイドを完成させました。
2 件のコメント
Hello, I dropped my Nexus 5 today and the front glass got broken; the LCD and the touch are working perfectly. Is it possible to only replace the front glass? Thanks
Hello there. My Lg Nexus5-D821 phone just went blackout, that is had a dark screen when it was charging.nothing is showing on the screen even if you try to switch it on its failing to show anything on the screen. Someone looking at it is failing to diagnose its problem. He tested the battery on another phone is charging. What should I do to fix it. Kindly assist.
