メインコンテンツにスキップ
How to clean Non-functoning buttons on remote
必要な工具と部品
  1. How to clean Non-functoning buttons on remote, How to clean Non-functoning buttons on remote: 手順 1、 1の画像 1
    • For later testing: X marks butttons which still work, O marks buttons that don't.
  2. How to clean Non-functoning buttons on remote: 手順 2、 2の画像 1 How to clean Non-functoning buttons on remote: 手順 2、 2の画像 2
    • Open battery housing and remove the batteries
    • Remove the screw located in the center of the battery housing
  3. How to clean Non-functoning buttons on remote: 手順 3、 1の画像 1
    • Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
    • Pry them open with a small flat head. If you're carefull that will leave only tiny scratches, but it does take some force
  4. How to clean Non-functoning buttons on remote: 手順 4、 2の画像 1 How to clean Non-functoning buttons on remote: 手順 4、 2の画像 2
    • Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote
    • If necessary, add contact spray or alike to the buttom of the rubber buttons
  5. How to clean Non-functoning buttons on remote: 手順 5、 1の画像 1
    • After cleaning and before full re-assembly, you might want to try if things improved.
    • Put the cicruit board back in, add batteries and put the rubber mats onto the circuit board
    • If the repair worked, you should the red top LED flashing
    • Put it all back together again. (Don't forget the screw in the battery housing.)
    • You might need some new batteries as well
終わりに
23 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
andre
メンバー登録日: 03/12/12
1,760 ポイント
4のガイドは作成済み
29 件のコメント
Having trouble with the latches. Can you explain the technique you used to pry them open?
Thanks!
bob - 返信
Hi Bob. Force, brute force. Sorry, I don't have a better advice for you. ;-)
andre -
thanks, I fixed mine using your guide.
surfer - 返信
You are a life saver, just fixed my onkyo RC-737m control with this guide... Broken a plastic clip but can't tell when it's back together. Cheers again! Leon
Leon Parsons - 返信
Géniaaaaaaaaaaal!
Deux télécommandes dont les boutons du volume ne répondaient plus! Et hop c'est revenu ;-)
Merciiiiiiii
Thierry Paulet - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 65
今までの合計 38,112
