メインコンテンツにスキップ
はじめに
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
パーツ
パーツは指定されていません。
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. Pull up on the tab to remove the batteries.
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. Your camera should look something like this.
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  3. Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  4. All cleaned up!
    • All cleaned up!
まとめ
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 の人々がこのガイドを完成させました。
Zachary Phillips
メンバー登録日: 2011年04月08日
205 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G26
3 メンバー
7のガイドは作成済み
コメント1件
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 54
今までの合計 12,145
