メインコンテンツにスキップ
How to clean Magnavox MWD200F gears
必要な工具と部品
  1. How to clean Magnavox MWD200F gears, Faceplate: 手順 1、 1の画像 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to clean Magnavox MWD200F gears: 手順 2、 1の画像 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to clean Magnavox MWD200F gears: 手順 3、 1の画像 1
    • Unclip the three latches on the bottom of the device.
  4. How to clean Magnavox MWD200F gears: 手順 4、 1の画像 1
    • Pull the faceplate off.
  5. How to clean Magnavox MWD200F gears, Disk Drive: 手順 5、 2の画像 1 How to clean Magnavox MWD200F gears, Disk Drive: 手順 5、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. How to clean Magnavox MWD200F gears: 手順 6、 2の画像 1 How to clean Magnavox MWD200F gears: 手順 6、 2の画像 2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. How to clean Magnavox MWD200F gears: 手順 7、 2の画像 1 How to clean Magnavox MWD200F gears: 手順 7、 2の画像 2
    • Pull out the silver security bar and set aside.
  8. How to clean Magnavox MWD200F gears: 手順 8、 1の画像 1
    • Take out the two screws on either side of the green circuit board.
  9. How to clean Magnavox MWD200F gears: 手順 9、 2の画像 1 How to clean Magnavox MWD200F gears: 手順 9、 2の画像 2
    • Carefully lift the board just enough to remove the disk drive.
  10. How to clean Magnavox MWD200F gears: 手順 10、 3の画像 1 How to clean Magnavox MWD200F gears: 手順 10、 3の画像 2 How to clean Magnavox MWD200F gears: 手順 10、 3の画像 3
    • Remove the two screws at the back of the disk drive.
  11. How to clean Magnavox MWD200F gears: 手順 11、 2の画像 1 How to clean Magnavox MWD200F gears: 手順 11、 2の画像 2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
  12. How to clean Magnavox MWD200F gears, How to clean Magnavox MWD200F gears: 手順 12、 2の画像 1 How to clean Magnavox MWD200F gears, How to clean Magnavox MWD200F gears: 手順 12、 2の画像 2
    • Turn disc drive over so you can see the gears on the bottom.
  13. How to clean Magnavox MWD200F gears: 手順 13、 2の画像 1 How to clean Magnavox MWD200F gears: 手順 13、 2の画像 2
    • Using a cotton swap or a cleansing cloth and alcohol, gently rub the gears ridding of any debris and dust.
    • You can also use a compressed air can as well. Just point the nozzle at the gears and spray with the compressed air.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Taryn
メンバー登録日: 09/15/11
109 ポイント
4のガイドは作成済み
チーム
University of Maine, Team 1-2, Diaz Fall 2011 University of Maine, Team 1-2, Diaz Fall 2011人のメンバー
UMAINE-DIAZ-F11S1G2
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 818
