ガイド紹介
Use this repair guide to clean sticky buttons.
パーツ
パーツは指定されていません。
  1. Use a slightly damp toothbrush to scrape in between the desired sticky buttons. Make sure toothbrush is not to the point of dripping water when scraping.
    • Use a slightly damp toothbrush to scrape in between the desired sticky buttons.
    • Make sure toothbrush is not to the point of dripping water when scraping.
  2. Android 修理キット
    交換用スクリーンやバッテリーの修理キット
    ショップを見る
    Android 修理キット
    ショップを見る
  3. Dry with a cloth after the sticky residue is removed.
    • Dry with a cloth after the sticky residue is removed.
ゴール
7 の人々がこのガイドを完成させました。
Adam
メンバー登録日: 2010年01月20日
667 Reputation
5のガイドは作成済み
チーム
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S16G29
5 メンバー
26のガイドは作成済み
3 Comments
I just used this method to clean sticky buttons on a wireless Xbox 360 controller. The Back, Xbox Guide, Start, X, Y, B, and A buttons were all sticky and unresponsive.
I removed the battery pack and followed the steps, and it worked like a charm. All of the buttons work just fine now except for the Xbox Guide button, which isn't really a big deal anyway.
This method works great. Thanks for making this guide, Adam.
Jeff Laxson - 返信
Wow. I thought I was going to have to buy a new Wii U Pro Controller, but this fixed my sticky B button. So simple. Thanks for saving me $50, friend.
Trevor Babcock - 返信
my d-pad needs cleaning, help?
Trace Ruby - 返信
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 33
All Time: 24,335
