メインコンテンツにスキップ
How to clean Game Boy Advance buttons
必要な工具と部品
  1. How to clean Game Boy Advance buttons, How to clean Game Boy Advance buttons: 手順 1、 2の画像 1 How to clean Game Boy Advance buttons, How to clean Game Boy Advance buttons: 手順 1、 2の画像 2
    • Use a slightly damp toothbrush to scrape in between the desired sticky buttons. You can also use a bit of isopropyl alcohol.
    • Make sure toothbrush is not to the point of dripping water when scraping.
  2. How to clean Game Boy Advance buttons: 手順 2、 1の画像 1
    • Dry with a cloth after the sticky residue is removed.
ゴール
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Adam
メンバー登録日: 01/20/10
851 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S16G29
5 メンバー
62のガイドは作成済み
3件のガイドコメント
I just used this method to clean sticky buttons on a wireless Xbox 360 controller. The Back, Xbox Guide, Start, X, Y, B, and A buttons were all sticky and unresponsive.
I removed the battery pack and followed the steps, and it worked like a charm. All of the buttons work just fine now except for the Xbox Guide button, which isn't really a big deal anyway.
This method works great. Thanks for making this guide, Adam.
Jeff Laxson - 返信
Wow. I thought I was going to have to buy a new Wii U Pro Controller, but this fixed my sticky B button. So simple. Thanks for saving me $50, friend.
Trevor Babcock - 返信
my d-pad needs cleaning, help?
Trace Ruby - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 18
過去 30 日: 66
今までの合計 28,344
