メインコンテンツにスキップ
How to clean Canon PowerShot A550 buttons
必要な工具と部品
  1. How to clean Canon PowerShot A550 buttons, Front and Back Covers: 手順 1、 3の画像 1 How to clean Canon PowerShot A550 buttons, Front and Back Covers: 手順 1、 3の画像 2 How to clean Canon PowerShot A550 buttons, Front and Back Covers: 手順 1、 3の画像 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. How to clean Canon PowerShot A550 buttons: 手順 2、 1の画像 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. How to clean Canon PowerShot A550 buttons: 手順 3、 1の画像 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. How to clean Canon PowerShot A550 buttons: 手順 4、 2の画像 1 How to clean Canon PowerShot A550 buttons: 手順 4、 2の画像 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. How to clean Canon PowerShot A550 buttons: 手順 5、 1の画像 1
    • The camera should look like this once the front cover is removed.
  6. How to clean Canon PowerShot A550 buttons: 手順 6、 3の画像 1 How to clean Canon PowerShot A550 buttons: 手順 6、 3の画像 2 How to clean Canon PowerShot A550 buttons: 手順 6、 3の画像 3
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. How to clean Canon PowerShot A550 buttons: 手順 7、 1の画像 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. How to clean Canon PowerShot A550 buttons, How to clean Canon PowerShot A550 buttons: 手順 8、 1の画像 1
    • Turn to the back of the camera body. Rub the function keys and surrounding area with a clean cloth dipped in isopropyl alcohol.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Shaelyn Thomas
メンバー登録日: 04/19/11
332 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S8G6
4 メンバー
22のガイドは作成済み
コメント 1 件
new Battery in side & massages is Battery low why?
Rupesh Jamsandekar - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,926
