メインコンテンツにスキップ
How to check Fujifilm FinePix S8200 for loose LCD connection
必要な工具と部品
  1. How to check Fujifilm FinePix S8200 for loose LCD connection, Batteries: 手順 1、 1の画像 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. How to check Fujifilm FinePix S8200 for loose LCD connection: 手順 2、 1の画像 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. How to check Fujifilm FinePix S8200 for loose LCD connection: 手順 3、 1の画像 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 手順 4、 3の画像 1 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 手順 4、 3の画像 2 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 手順 4、 3の画像 3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. How to check Fujifilm FinePix S8200 for loose LCD connection: 手順 5、 3の画像 1 How to check Fujifilm FinePix S8200 for loose LCD connection: 手順 5、 3の画像 2 How to check Fujifilm FinePix S8200 for loose LCD connection: 手順 5、 3の画像 3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. How to check Fujifilm FinePix S8200 for loose LCD connection: 手順 6、 1の画像 1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. How to check Fujifilm FinePix S8200 for loose LCD connection, How to check Fujifilm FinePix S8200 for loose LCD connection: 手順 7、 1の画像 1
    • Fold back the LCD screen and check that the cable coming from the screen is securely fastened to the motherboard.
  8. How to check Fujifilm FinePix S8200 for loose LCD connection: 手順 8、 1の画像 1
    • Fold the LCD screen back into the proper position.
終わりに
作成者
3人の作成者と共同で作成されました。
Joseph Kelley
メンバー登録日: 01/15/15
228 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015人のメンバー
USFT-REMMELL-W15S7G1
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 700
