メインコンテンツにスキップ
How to charge Canon PowerShot A4000 IS battery
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. How to charge Canon PowerShot A4000 IS battery, Battery: 手順 1、 1の画像 1
    • Using your finger, apply light pressure to the grooves at the top right corner of the camera to slide the door to the battery compartment open.
  2. How to charge Canon PowerShot A4000 IS battery, Inside The Battery Compartment: 手順 2、 2の画像 1 How to charge Canon PowerShot A4000 IS battery, Inside The Battery Compartment: 手順 2、 2の画像 2
    • Using your finger, press the red switch backwards, away from the lens to release the battery.
    • The battery has an arrow on it pointing in the direction the battery needs to be oriented in the camera.
  3. How to charge Canon PowerShot A4000 IS battery, Charging the Battery: 手順 3、 3の画像 1 How to charge Canon PowerShot A4000 IS battery, Charging the Battery: 手順 3、 3の画像 2 How to charge Canon PowerShot A4000 IS battery, Charging the Battery: 手順 3、 3の画像 3
    • Use the Battery Removal guide to remove your camera battery. Once the battery is removed, insert it into the charger that came with your PowerShot A4000 camera.
    • Maker sure the arrows on the charger and camera match up or the battery will not charge properly.
    • Once the battery is inserted into the charger, it is ready to be plugged into an outlet.
    • A yellow light will come on once the battery begins charging. The light will turn green when the battery is fully charged.
  4. How to charge Canon PowerShot A4000 IS battery, Reinserting the Battery: 手順 4、 2の画像 1 How to charge Canon PowerShot A4000 IS battery, Reinserting the Battery: 手順 4、 2の画像 2
    • Once the battery is fully charged, use the guide on removing your camera battery found here: Battery Removal, in reverse, to reinsert your battery.
    • Make sure to line up the battery with the arrow side facing toward the lens side of the camera. When you press the battery down, the red switch should click back into place automatically, holding the battery in place.
終わりに
作成者
3人の作成者と共同で作成されました。
Ansley Gardner
メンバー登録日: 10/13/14
761 ポイント
7のガイドは作成済み
チーム
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G3
3 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 601
