メインコンテンツにスキップ
How to build a Mailbox out of an old Apple G5 Mac Pro tower
必要な工具と部品
  1. How to build a Mailbox out of an old Apple G5 Mac Pro tower, How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 1、 3の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower, How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 1、 3の画像 2 How to build a Mailbox out of an old Apple G5 Mac Pro tower, How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 1、 3の画像 3
    • The Making of a Power Mac g5 Mailbox
  2. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 2、 3の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 2、 3の画像 2 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 2、 3の画像 3
    • Tools Needed
  3. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 3、 2の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 3、 2の画像 2
    • Mark where you are going to have to cut
  4. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 4、 2の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 4、 2の画像 2
    • Cut a hole big enough to slide the mailbox into the case
  5. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 5、 3の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 5、 3の画像 2 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 5、 3の画像 3
    • Drill 4 holes through the bottom of the case and put wood underneath the case and screw the wood pieces to the bottom of the mailbox. Put a piece of wood under the mailbox to have something to screw it to. You may have to drill more holes to screw the boards together with long screws.
  6. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 6、 1の画像 1
    • Slide in the mailbox and then put screws into the side of the mailbox going into the wood underneath.
  7. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 7、 1の画像 1
    • Put a screw in the front and back of the inside of the mailbox.
  8. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 8、 3の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 8、 3の画像 2 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 8、 3の画像 3
    • Using the flag as a guide to where to drill the holes. Mark a spot for a hole for the flag to go through in the door of the case. Then drill holes accordingly.
  9. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 9、 2の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 9、 2の画像 2
    • Insert an S hook and use pliers to close the S hook around the plastic connector to hold the flag on.
  10. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 10、 3の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 10、 3の画像 2 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 10、 3の画像 3
    • Take a rubber fuel line and wrap it in silver hvac tape and slit the hose down the middle to make a seal to fill in the gaps between the mailbox. The silver tape is optional.
  11. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 11、 2の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 11、 2の画像 2
    • Use the silver tape to cover the screw heads inside of the mailbox.
  12. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 12、 3の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 12、 3の画像 2 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 12、 3の画像 3
    • Take a flower pot and cut a hole in it to make a concrete base (optional) Mix the quickcrete up and fill the flower pot with it and flip it over and stick the wood pole in the concrete.
    • Use a level and something to hold the wood in a level position while it dries
  13. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 13、 2の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 13、 2の画像 2
    • Paint the wood pole and the concrete white.
  14. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 14、 1の画像 1
    • Using L metal brackets screw the mailbox to the pole.
  15. How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 15、 2の画像 1 How to build a Mailbox out of an old Apple G5 Mac Pro tower: 手順 15、 2の画像 2
    • Put the side panel with the flag back on and you should have finished mail box ready to be buried or in this case used as a self standing mailbox.
終わりに
By the end of this guide you should have yourself a Mac Mailbox.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
joe
メンバー登録日: 12/31/13
3,320 ポイント
1ガイドが承認済み
チーム
Joespcrepairs.com Joespcrepairs.com人のメンバー
Business
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 968
