メインコンテンツにスキップ
How to assign devices with a CSV file in Mosyle
  1. How to assign devices with a CSV file in Mosyle, Preparing your Data: 手順 1、 2の画像 1 How to assign devices with a CSV file in Mosyle, Preparing your Data: 手順 1、 2の画像 2
    • To start you'll need to get the CSV file from Mosyle's website. Go to My School > Device Assignment > Spreadsheet Assignment.
    • Under the section that says Download the template, and click Download CSV
  2. How to assign devices with a CSV file in Mosyle, Open the CSV: 手順 2、 1の画像 1
    • Once the CSV file is downloaded open it in your spreadsheet program of choice.
    • The CSV will look something like this, but once we start entering user data you can delete the bottom most row.
  3. How to assign devices with a CSV file in Mosyle, Enter the user data: 手順 3、 1の画像 1
    • Delete the cells that contain SERIAL_NUMBER_SAMPLE, USER_ID_SAMPLE, and CART_NAME.
    • Enter the device's serial number in the bottom row first column.
    • Enter either the User's ID or the Cart name in there respective column's. .
    • At least one of these need to be filled. Cart Name is optional as long as you have the User ID.
    • Once all your data is entered save the spreadsheet as a CSV file and upload the file to Mosyle by clicking Select File on the Spreadsheet Assignment page, and select your CSV file.
    • It will take Mosyle a bit to process your file. Any errors in user data will be reported once your file is finished uploading.
終わりに
While their are several different ways of assigning devices through Mosyle, CSV assignment is one of the easiest ways of assigning a large group of devices if you already have student information in a preexisting spreadsheet.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jacob Mehnert
メンバー登録日: 10/18/21
44,284 ポイント
51のガイドは作成済み
チーム
iFanatics iFanatics人のメンバー
Community
63 メンバー
218のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 1,308
