メインコンテンツにスキップ
How to align Razor A steering
必要な工具と部品
  1. How to align Razor A steering, How to align Razor A steering: 手順 1、 3の画像 1 How to align Razor A steering, How to align Razor A steering: 手順 1、 3の画像 2 How to align Razor A steering, How to align Razor A steering: 手順 1、 3の画像 3
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
    at this part it would easily loosen for a few seconds then get hard again can you update this and mention that please if its normal
    Caleb Rigby (Awesomegamez) - 返信
    After loosening and re-aligning make sure to tighten it back up really tight so the problem will be avoided for a while. Eventually you will probably have to do this again after using the scooter a lot.
    Nolan Proulx - 返信
  2. How to align Razor A steering: 手順 2、 2の画像 1 How to align Razor A steering: 手順 2、 2の画像 2
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
ゴール
16 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jordyn
メンバー登録日: 10/09/12
544 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G13
4 メンバー
10のガイドは作成済み
4 件のコメント
This is so unhelpful.
Linh Tran - 返信
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - 返信
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - 返信
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 92
今までの合計 29,771
