メインコンテンツにスキップ
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: 手順 1、 2の画像 1 How to adjust Razor A steering column, How to adjust Razor A steering column: 手順 1、 2の画像 2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: 手順 2、 1の画像 1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
ゴール
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jordyn
メンバー登録日: 10/09/12
544 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G13
4 メンバー
10のガイドは作成済み
8 件のコメント
what move it with your hands? - didn't help
Heather McCasland - 返信
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - 返信
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - 返信
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - 返信
My son just opened his brand new razor scooter and the head set is very loose. From past bicycle experience this will cause premature bearing failure and likely strip out the steering stem. This will in turn cost more to repair than it would be to replace the entire scooter. Are these headsets supposed to be loose from the factory?
mgenius33 - 返信
I can’t get it, gonna have to bring it in a bike shop for repair
Joe DeVito - 返信
Thank you so much! You made my day.
Ntro Nitro - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 30
過去 30 日: 186
今までの合計 40,963
