メインコンテンツにスキップ
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: 手順 1、 2の画像 1 How to adjust Razor A steering column, How to adjust Razor A steering column: 手順 1、 2の画像 2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: 手順 2、 1の画像 1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
ゴール
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jordyn
メンバー登録日: 10/09/12
565 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G13
4 メンバー
10のガイドは作成済み
8件のガイドコメント
what move it with your hands? - didn't help
Heather McCasland - 返信
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - 返信
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - 返信
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 74
今までの合計 43,259
