はじめに
Correctly tensioned brake cables are very important to the proper operation of your bike.
If the cables are too loose, you won't actually be able to pull enough on the brake levers for the braking mechanism to drag hard enough on the rim of the wheel, and thus you will have trouble stopping.
On the contrary, if the cables are too tight, your brakes will be constantly rubbing against the rim of the wheel, adding friction and making any part of the ride that much harder.
Either way, this guide will show you how to adjust the tension on your brake cable to your liking, so that you can brake when you need to and ride easily the rest of the time.
必要な工具と部品
Use the two wrenches to loosen the nut that holds the brake cable to the braking mechanism. Grip the nut with one wrench, then grip the bolt (on the other side) with the second wrench.
You might want to enlist a friend to hold on to the end of the cable for you so it doesn't fall off when you loosen the nut that holds it down.
Now, your brakes should be all tuned up and ready to ride.
