メインコンテンツにスキップ
How to a Fix a Microwave Oven
必要な工具と部品
ビデオの概要
  1. How to a Fix a Microwave Oven, Magnetron, capacitor, fuse or diode.: 手順 1、 1の画像 1
    • Don't forget to read the video description on YouTube here: https://youtu.be/WAf18e8sW4E
    • Be sensible! Take precautions like not powering it up uncovered, allowing time for high voltages to discharge. See the video description on YouTube and take note of safety advice. Don't be afraid, but just be sensible.
終わりに
A standard microwave oven is actually a simple device comprising of a transformer, diode, capacitor, a fuse and the magnetron valve. All can be tested and replaced to fix a non heating oven. Watch the video.
35 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
jon
メンバー登録日: 05/15/16
3,210 ポイント
22のガイドは作成済み
14件のガイドコメント
Very simple,that mean very good
eugen - 返信
My Whirlpool over the counter microwave which is giving me no problems at all it is only 2 years old. As I was heating up my dinner it worked fine I heated Something else up then all of a sudden it tells me to close the door and push start and when I push start it just clicks and does nothing else everything else on the microwave seems to be working
mddixiedarlin - 返信
How about replacing a wave guide with a hole burned through it? (arcing)
Whirlpool small microwave.
Hank - 返信
That star screw head is actually called a Torx security screw, the pin in the middle is what makes it a security screw. A mating Torx bit or driver of the appropriate size. You can buy a set of them or a combination set with standard from GearBest from the UK. They are fairly common in the U.S. In Dollars, they cost around 8.00-20.00. eBay is a good source, also. Thank you for enlightening me on what to look for and expect. My 15-year-old Panasonic has been flawless, until tonight.
Ron LHeureux - 返信
Lg convection microven some times re start after 2 seconds 10 seconds
Manas Guchait - 返信
コメントを追加
統計データ:
過去 24時間: 31
過去 7 日: 173
過去 30 日: 692
今までの合計 54,577
