メインコンテンツにスキップ
How to Unclog a Shower Drain
必要な工具と部品
  1. How to Unclog a Shower Drain, How to Unclog a Shower Drain: 手順 1、 1の画像 1
    • Begin by putting on a pair of disposable gloves to protect your hands from what is inside your drain and from the chemicals in drain opener.
  2. How to Unclog a Shower Drain: 手順 2、 3の画像 1 How to Unclog a Shower Drain: 手順 2、 3の画像 2 How to Unclog a Shower Drain: 手順 2、 3の画像 3
    • Remove the stopper from your shower drain, if possible.
    • Follow this link to determine how to remove the specific kind of drain stopper you have.
  3. How to Unclog a Shower Drain: 手順 3、 2の画像 1 How to Unclog a Shower Drain: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Once the drain stopper is out of the way, use your fingers, tweezers, or almost any long thin object to pull out hair and larger items clogging the drain.
    • Dispose of anything you were able to remove from your drain.
    • If you cannot remove your drain stopper, skip ahead until step 7.
  4. How to Unclog a Shower Drain: 手順 4、 2の画像 1 How to Unclog a Shower Drain: 手順 4、 2の画像 2
    • If you are unable to lift out the hair and larger items in your drain, consider using a plunger.
    • Cover the drain with a plunger and run the water in your bathtub or shower until it covers at least half of the plunger.
  5. How to Unclog a Shower Drain: 手順 5、 2の画像 1 How to Unclog a Shower Drain: 手順 5、 2の画像 2
    • Without breaking the seal of the plunger on the drain, push the plunger sharply down and up a few times.
  6. How to Unclog a Shower Drain: 手順 6、 3の画像 1 How to Unclog a Shower Drain: 手順 6、 3の画像 2 How to Unclog a Shower Drain: 手順 6、 3の画像 3
    • Push down on the plunger again, but pull up sharply to break the seal.
    • This will hopefully dislodge what is clogging the drain. Any residual items may be removed as in step 3.
  7. How to Unclog a Shower Drain: 手順 7、 1の画像 1
    • The chemicals in drain opener are very dangerous. Wear gloves to avoid the liquid touching your skin.
    • If you are unable to unclog your drain by hand, consider using liquid drain opener.
    • The drain opener you purchased should have instructions on the back which will tell you how much of the drain cleaner to use.
  8. How to Unclog a Shower Drain: 手順 8、 2の画像 1 How to Unclog a Shower Drain: 手順 8、 2の画像 2
    • Slowly pour the liquid drain opener down the drain, but avoid pouring the liquid on your shower floor and drain stopper.
    • If you were unable to remove the drain stopper, lift the stopper up as much as possible and follow the steps above.
  9. How to Unclog a Shower Drain: 手順 9、 1の画像 1
    • Wait at least the time stated on your bottle of drain opener.
    • Different drain openers have different wait times, ranging from 10 minutes to 10 hours.
    • Regardless of the instructions, the longer you let the drain opener sit in your drain, the more effective it will be.
  10. How to Unclog a Shower Drain: 手順 10、 2の画像 1 How to Unclog a Shower Drain: 手順 10、 2の画像 2
    • After an appropriate amount of time, run hot water down the drain to flush out any remaining blockage.
終わりに
To reassemble your drain stopper, follow the steps you took in step one in reverse order.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kathryn Breitenstein
メンバー登録日: 09/29/15
200 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-7, Green Fall 2015 Cal Poly, Team 10-7, Green Fall 2015人のメンバー
CPSU-GREEN-F15S10G7
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 73
今までの合計 3,229
