メインコンテンツにスキップ
How to Unclog a Shower Drain
必要な工具と部品
  1. How to Unclog a Shower Drain, How to Unclog a Shower Drain: 手順 1、 1の画像 1
    • Gloves are optional should you desire them. They may help to keep yourself as clean as possible.
  2. How to Unclog a Shower Drain: 手順 2、 3の画像 1 How to Unclog a Shower Drain: 手順 2、 3の画像 2 How to Unclog a Shower Drain: 手順 2、 3の画像 3
    • Remove the drain snake from it's packaging. Be sure to straighten out your drain snake as much as possible for ease of use.
    • Make sure that its edges are firm, or else it will not be able to snag the material easily.
  3. How to Unclog a Shower Drain: 手順 3、 1の画像 1
    • Unscrew the drain. This step is also optional, but it will be easier to help utilize the drain snake to its max potential.
    • After removing the handle, use a screwdriver to remove the rest of the drain.
  4. How to Unclog a Shower Drain: 手順 4、 3の画像 1 How to Unclog a Shower Drain: 手順 4、 3の画像 2 How to Unclog a Shower Drain: 手順 4、 3の画像 3
    • Make sure drain is not closed throughout this step.
    • Stick your drain snake as deep into the drain gateway as you can. The further down you go, the greater the results. May also vary depending on status of drain.
  5. How to Unclog a Shower Drain: 手順 5、 2の画像 1 How to Unclog a Shower Drain: 手順 5、 2の画像 2
    • Spin and turn the drain snake around to gather as much material as you can.
    • After removing drain snake, extract all material from the snake and dispose of it in the garbage. Repeat this step until you have reached satisfactory results.
  6. How to Unclog a Shower Drain: 手順 6、 3の画像 1 How to Unclog a Shower Drain: 手順 6、 3の画像 2 How to Unclog a Shower Drain: 手順 6、 3の画像 3
    • Take out your pump and a container full of warm water.
    • Extract water from your container and exert pressure into the drain to clean it out.
    • Repeat step a few times, and then test the status of your drain by starting up your bath tub and seeing if water flows naturally down the drain.
    • If everything goes as planned, your bath tub drain should be of good use again!
終わりに
作成者
1人の作成者と共同作成されました。
Preston Aguada
メンバー登録日: 07/27/20
133 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G1, Cardinal Summer 2020 UW Tacoma, Team S1-G1, Cardinal Summer 2020人のメンバー
UWT-CARDINAL-SU20S1G1
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 527
