メインコンテンツにスキップ
How to Unclog a Samsung WF350ANR Washing Machine Filter
必要な工具と部品
  1. How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 1、 3の画像 1 How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 1、 3の画像 2 How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 1、 3の画像 3
    • Caution: Before beginning this guide, be sure to turn the washing machine off and unplug it from the outlet.
    • The water filter is typically located at the bottom right or bottom left. In this case, it is located at the bottom right.
    • Place a bucket under the water filter to capture excess water before moving on to the next steps.
  2. How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 2、 3の画像 1 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 2、 3の画像 2 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 2、 3の画像 3
    • Jiggle the water filter compartment while pulling it towards yourself to remove the compartment.
  3. How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 3、 3の画像 1 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 3、 3の画像 2 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 3、 3の画像 3
    • To open the water filter, move the knob to the left with your hand.
    • With your other hand, hold the bucket underneath the filter to capture the excess water.
  4. How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 4、 3の画像 1 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 4、 3の画像 2 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 4、 3の画像 3
    • Remove the water filter.
    • Clean hard-to-reach places in the filter with a toothbrush and excess water that was captured with the bucket.
  5. How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 5、 2の画像 1 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 5、 2の画像 2
    • Use the toothbrush to clean the slot in the washing machine where the water filter is inserted.
  6. How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 6、 3の画像 1 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 6、 3の画像 2 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 6、 3の画像 3
    • Inspect the inside to make sure there is no leftover lint or unnecessary objects that can clog the water filter.
  7. How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 7、 3の画像 1 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 7、 3の画像 2 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 7、 3の画像 3
    • Place the water filter back into the washing machine.
    • Turn the filter to the right to tighten it.
  8. How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 8、 2の画像 1 How to Unclog a Samsung WF350ANR Washing Machine Filter: 手順 8、 2の画像 2
    • Pour the bucket of excess water down a drain.
    • If a lot of lint or hair was cleaned out of the water filter, make sure to grab it with one hand as you drain out the water with the other hand.
    • Discard the lint and hair in the trash.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jasmine Andrade
メンバー登録日: 04/11/21
181 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team S1-G9, Harris Spring 2021 CSU Los Angeles, Team S1-G9, Harris Spring 2021人のメンバー
CSULA-HARRIS-S21S1G9
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 65
今までの合計 1,240
