はじめに
When an Epson Workforce 2760 printer has been idle for too long, the ink heads tend to harden and thus documents do not print properly. Instead of tossing the printer, there is an easy fix to unclog the ink heads that will save time, money and the environment.
必要な工具と部品
In the "Settings" menu, set the printer cartridges to "Replace ink cartridges."
After one hour, repeat steps one through four on the other ink heads.
Move the ink slot back into place, and insert the new ink cartridges.
Under "Settings," finish replacing ink cartridges process.
Print a "test page" and if the results shown on image three appear, the printer heads are successfully unclogged.
もう少しです!
ゴール
