メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to True a wheel
必要な工具と部品
    1. How to True a wheel, How to True a wheel: 手順 1、 2の画像 1 How to True a wheel, How to True a wheel: 手順 1、 2の画像 2
      • Fit the wheel into the wheel truing stand.
      • The wheel should be snug and securely fixed to the stand.
      • Make sure hub does not have play in it since this will impede your ability to true the wheel.
      FixBotに聞いてみる
      コメントを追加
    2. How to True a wheel: 手順 2、 2の画像 1 How to True a wheel: 手順 2、 2の画像 2
      • Slowly rotate the wheel.
      • Slowly tighten the calipers until they touch at some point on only one side of the rim.
      FixBotに聞いてみる
      コメントを追加
    3. How to True a wheel: 手順 3、 2の画像 1 How to True a wheel: 手順 3、 2の画像 2
      • Select the a spoke wrench that fits the spokes on your wheel.
      • Loosen the spokes that attach to the same side of the wheel as the caliper contact point. At the same time, tighten the spokes that attach to the opposite side of the wheel as the caliper contact point. To start, try a half turn for each of the spokes near the caliper contact point.
      • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
      • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until when tightening the calipers, they touch both sides of the rim evenly at every point on the rim.
      FixBotに聞いてみる
      コメントを追加
終わりに
The wheel should spin without wobbling from side to side or wavering up and down.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
aaron thielk
メンバー登録日: 10/10/10
1,984 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S5G13
4 メンバー
21のガイドは作成済み
2件のガイドコメント
This is a great instruction manual. I especially appreciated the pictures. For those of us who have never fixed a bike, I would not know what a caliper was without the picture.
Thanks!
edwardslaura234 - 返信 共有
If you don't want to spend money on wheel callipers. Use clothes hanger and tape to the break as a guide.
deankjm - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 35
今までの合計 8,015
