メインコンテンツにスキップ
How to True a Bent Bicycle Rim Using Common Tools
必要な工具と部品
  1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: 手順 1、 1の画像 1
    • Bring your bike somewhere with ample space so you have room to work.
  2. How to True a Bent Bicycle Rim Using Common Tools: 手順 2、 3の画像 1 How to True a Bent Bicycle Rim Using Common Tools: 手順 2、 3の画像 2 How to True a Bent Bicycle Rim Using Common Tools: 手順 2、 3の画像 3
    • Flip the bike on its seat so the wheel can spin freely.
    • Use the spokes to spin the affected wheel.
    • Continue spinning the wheel until it is clear where the bend is occurring.
  3. How to True a Bent Bicycle Rim Using Common Tools: 手順 3、 2の画像 1 How to True a Bent Bicycle Rim Using Common Tools: 手順 3、 2の画像 2
    • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
  4. How to True a Bent Bicycle Rim Using Common Tools: 手順 4、 3の画像 1 How to True a Bent Bicycle Rim Using Common Tools: 手順 4、 3の画像 2 How to True a Bent Bicycle Rim Using Common Tools: 手順 4、 3の画像 3
    • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
  5. How to True a Bent Bicycle Rim Using Common Tools: 手順 5、 2の画像 1 How to True a Bent Bicycle Rim Using Common Tools: 手順 5、 2の画像 2
    • Pluck the spoke and listen to the pitch to check its tightness.
    • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
  6. How to True a Bent Bicycle Rim Using Common Tools: 手順 6、 2の画像 1 How to True a Bent Bicycle Rim Using Common Tools: 手順 6、 2の画像 2
    • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
  7. How to True a Bent Bicycle Rim Using Common Tools: 手順 7、 1の画像 1
    • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
    • Repeat the tightening/loosening process accordingly if necessary.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Charles Tweedy
メンバー登録日: 04/19/23
163 ポイント
1ガイドが承認済み
チーム
UCD-MORRIS-S23S1G4 UCD-MORRIS-S23S1G4人のメンバー
Community
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 17
今までの合計 923
