メインコンテンツにスキップ
How to Troubleshoot a GE Dryer Not Heating
必要な工具と部品
    • Remove and inspect the filter inside the dryer for any clogs or debris.
    • Rinse the filter under warm water to clear invisible residue left by dryer sheets.
    • Dry and reinstall the filter, then confirm that airflow is unrestricted in the filter housing.
    • Move the dryer to access the rear panel where the power cord enters.
    • Remove the lower panel screw with a quarter inch hex head driver and open the panel.
    • Look for any signs of damage or burnt wiring on the terminal block or cord.
    • Use a multimeter set to AC voltage to confirm 120 volts on each leg to neutral and about 208 to 240 volts across both hot legs.
    • Reset the breaker by turning it off, then cycling on, if voltage is incorrect, or replace the cord or consult an electrician if the outlet is faulty.
    • Set the multimeter to continuity or ohms resistance. Ensure the dryer is UNPLUGGED for this and future tests that involve continuity or ohms.
    • Place one meter lead on each side of the fuse near the bottom of the rear housing.
    • Replace the fuse if the meter stays open line and does not show 0.00 ohms.
    • Remove the two screws on each side of the plastic console with a quarter inch hex or Phillips bit.
    • Remove the four screws holding the metal panel behind the console and lift the panel off.
    • Refer to the schematic stored here for terminal labels and timer contact points.
    • Use the multimeter on continuity or ohms to test the correct timer contacts while rotating the knob to a heat setting.
    • If no continuity is found on the proper contacts at any setting, replace the timer.
    • Inspect the dial and shaft for damage if the knob fails to rotate the timer internally.
    • Remove two rear chassis screws on each side, then remove the two front screws inside the door opening.
    • Use a pry tool or screwdriver to lift the top panel of the dryer slightly. The top could be gently tilted rearward to rest on the wall for easier belt - top access.
    • Remove two hex head screws on each inside corner, then release the door harness connector carefully.
    • Lift the whole front door assembly off the lower hinge fingers, but note the short door lock harness.
    • Move the door aside or support it while disconnecting the door switch harness from the plastic cover.
    • Reach behind the blower housing on the right side to release tension on the idler pulley.
    • Detach the belt from the motor pulley and guide the belt free so the drum can lift out.
    • Pull the drum forward, following the shape of the dryer cabinet to avoid snagging.
    • Vacuum any lint or debris inside the cabinet and motor area to improve airflow.
    • Check the purple wire on the lower right corner of the heater pan for burning or charring.
    • Replace the wire if it appears damaged using a suitable wire kit specified by the device.
    • Examine the spade terminal on the heater pan for burn marks that may require replacing the entire heater assembly.
    • Disconnect one wire from the element carefully to avoid sharp edges.
    • Use the multimeter on ohms or continuity and expect about 43 ohms for a healthy heating element.
    • Move one lead to the purple wire side and measure about 21 ohms to each half of the element coils.
    • Replace the heating element if readings show open line or are significantly off from expected values.
    • Set the multimeter to ohms or continuity when testing each thermostat or safety fuse.
    • Remove at least one wire from each thermostat or fuse to prevent false readings.
    • Verify each large terminal shows near 0.00 ohms or a beep of continuity if in working condition.
    • Check small terminals for around 9000 ohms on sensor style thermostats, replacing them if values are off.
    • Replace any component that reads open line (OL) or has abnormal readings.
    • Hook the idler pulley on the motor mount before sliding the drum into the cabinet using the belt.
    • Align the rear drum bearing into its socket and confirm no obstructions by rotating the drum.
    • Attach the belt onto the motor pulley and release the idler pulley to restore tension.
    • Hang the front door panel on the lower chassis fingers and reconnect any door harness wiring.
    • Tighten all front and rear chassis screws to secure the door and top panel in place.
    • Reconnect the console by aligning its tabs and reinstall any screws that hold it together.
    • Plug in the dryer and run it briefly to verify proper drum rotation and heating performance.
終わりに
These steps target the most common reasons a GE dryer fails to heat, including airflow obstructions, faulty wiring, and defective components. Confirm correct installation of each part and recheck all connections after any replacement. If problems persist, consult a professional electrician or appliance specialist.
作成者
2人の作成者と共同で作成されました。
Ben Schlichter
メンバー登録日: 01/21/25
2,183 ポイント
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 31
過去 30 日: 143
今までの合計 1,496
