メインコンテンツにスキップ
How to Troubleshoot Generic 1A USB Car Charger
必要な工具と部品
  1. How to Troubleshoot Generic 1A USB Car Charger, How to Troubleshoot Generic 1A USB Car Charger: 手順 1、 1の画像 1
    • Insert the USB Micro end into the breakout, and insert the adapter into a power source, set for 12V (or automatic if in vehicle).
    • Caution: Since your device is connected to a power source, there is a low voltage current going through that could damage components.
  2. How to Troubleshoot Generic 1A USB Car Charger: 手順 2、 3の画像 1 How to Troubleshoot Generic 1A USB Car Charger: 手順 2、 3の画像 2 How to Troubleshoot Generic 1A USB Car Charger: 手順 2、 3の画像 3
    • Set the multimeter to VDC, and place the leads as shown.
    • The voltage should be about 5V.
    • If the voltage is lower, check the output of the power supply. If the power supply voltage is above 6V, then we will need to continue to Step 4.
  3. How to Troubleshoot Generic 1A USB Car Charger: 手順 3、 3の画像 1 How to Troubleshoot Generic 1A USB Car Charger: 手順 3、 3の画像 2 How to Troubleshoot Generic 1A USB Car Charger: 手順 3、 3の画像 3
    • Unscrew the tip to uncover the fuse.
    • Remove the fuse from the charger.
    • Make sure to document the order that everything is unscrewed. This will be important for reassembly.
  4. How to Troubleshoot Generic 1A USB Car Charger: 手順 4、 2の画像 1 How to Troubleshoot Generic 1A USB Car Charger: 手順 4、 2の画像 2
    • Set the multimeter to test continuity.
    • Test to know how your meter reads a closed circuit.
    • Test the fuse with the multimeter.
    • If your fuse does not allow a current to flow, you will need to replace it.
  5. How to Troubleshoot Generic 1A USB Car Charger: 手順 5、 2の画像 1 How to Troubleshoot Generic 1A USB Car Charger: 手順 5、 2の画像 2
    • If the fuse is allowing a current to flow, you may move on, opening the body of the charger.
    • Be aware, there may be small springs inside body.
    • Look for small breaks in the small wires. Repair of these types of problems are outside the scope of this iFixit guide, but other guides may help.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jay R Fude
メンバー登録日: 10/10/18
299 ポイント
1ガイドが承認済み
チーム
Missouri Western, Team S1-G2, Cools Stephens Fall 2018 Missouri Western, Team S1-G2, Cools Stephens Fall 2018人のメンバー
MWSU-COOLS STEPHENS-F18S1G2
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 40
今までの合計 1,558
