メインコンテンツにスキップ
How to Tighten Loose Bike Spokes
必要な工具と部品
  1. How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 手順 1、 3の画像 1 How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 手順 1、 3の画像 2 How to Tighten Loose Bike Spokes, How to Tighten Loose Bike Spokes: 手順 1、 3の画像 3
    • Place the bike in a position where you can comfortably access the wheel.
  2. How to Tighten Loose Bike Spokes: 手順 2、 1の画像 1
    • Inspect the wheel and look for loose spokes.
  3. How to Tighten Loose Bike Spokes: 手順 3、 3の画像 1 How to Tighten Loose Bike Spokes: 手順 3、 3の画像 2 How to Tighten Loose Bike Spokes: 手順 3、 3の画像 3
    • Use a spoke wrench to tighten the spoke. Retighten the spoke clockwise a quarter turn at a time.
  4. How to Tighten Loose Bike Spokes: 手順 4、 2の画像 1 How to Tighten Loose Bike Spokes: 手順 4、 2の画像 2
    • Since you just adjusted the tension of a spoke, we need to make sure the tension in all the spokes is equal throughout.
    • Use the spoke wrench to adjust the rest of the spokes as needed so that they all have equal tension. Turn the spoke wrench clockwise a quarter at a time.
  5. How to Tighten Loose Bike Spokes: 手順 5、 1の画像 1
    • Once the spokes are tightened, relieve the tension in the spokes by squeezing them.
    • This is to check that your spokes are now secure and won’t get loose.
    • Be sure to give the loose spokes an extra test to make sure they are now sturdy.
  6. How to Tighten Loose Bike Spokes: 手順 6、 1の画像 1
    • Spin the wheel to make sure the spokes are secure and to make sure that the wheel does not need additional truing.
ゴール
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Pavle Janev
メンバー登録日: 01/12/22
184 ポイント
1ガイドが承認済み
チーム
York University, Team S-11, Woodhouse Winter 2022 York University, Team S-11, Woodhouse Winter 2022人のメンバー
YORK-WOODHOUSE-W22SSG11
1 メンバー
1のガイドは作成済み
コメント 1 件
You should notice the tension spoke when tightening your bike spoke because it will affect the wheel’s stability. Tighten clockwise and turning the wrench in small increments of about a quarter turn will allow you to avoid tightening too much.
Dalton - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 52
今までの合計 6,542
