メインコンテンツにスキップ
How to Take in a Dress by Hand
必要な工具と部品
  1. How to Take in a Dress by Hand, How to Take in a Dress by Hand: 手順 1、 1の画像 1
    • Lay the dress flat on a table.
  2. How to Take in a Dress by Hand: 手順 2、 2の画像 1 How to Take in a Dress by Hand: 手順 2、 2の画像 2
    • Measure the bust and waist of the dress with the measuring tape and write the measurements down.
    • Measure your own bust and waist. Subtract the your measurements from the dress measurements.
    • Divide these numbers by two.
    • This is the amount of fabric that will be removed from each side.
  3. How to Take in a Dress by Hand: 手順 3、 1の画像 1
    • Turn the dress inside out.
    • Use the marker to mark the amount of bust and waist fabric that you are taking in for both sides.
  4. How to Take in a Dress by Hand: 手順 4、 1の画像 1
    • Connect the marks with sewing pins (or safety pins) to make a clear path to sew along.
  5. How to Take in a Dress by Hand: 手順 5、 3の画像 1 How to Take in a Dress by Hand: 手順 5、 3の画像 2 How to Take in a Dress by Hand: 手順 5、 3の画像 3
    • Thread the needle and leave plenty of excess thread for tying knots.
    • Start at the bottom of the new hem and weave the needle in and out of the dress until you reach the other side.
    • Tie a few knots at the end and cut the excess thread.
    • Now the new hem has been made.
  6. How to Take in a Dress by Hand: 手順 6、 3の画像 1 How to Take in a Dress by Hand: 手順 6、 3の画像 2 How to Take in a Dress by Hand: 手順 6、 3の画像 3
    • Cut off the excess fabric with the fabric scissors. Stay about a centimeter away from the sewed line to make sure you do not cut the thread.
  7. How to Take in a Dress by Hand: 手順 7、 2の画像 1 How to Take in a Dress by Hand: 手順 7、 2の画像 2
    • Repeat all of the previous steps on the other side of the dress.
    • Turn your dress inside right, and that completes this guide.
ゴール
作成者
1人の作成者と共同作成されました。
Olivia Collins
メンバー登録日: 03/23/21
145 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S1-G7, Gulbrandsen Spring 2021 UMass Dartmouth, Team S1-G7, Gulbrandsen Spring 2021人のメンバー
UMASSD-GULBRANDSEN-S21S1G7
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 73
今までの合計 9,975
