メインコンテンツにスキップ
How to Tailor Your Pants
必要な工具と部品
  1. How to Tailor Your Pants, How to Tailor Your Pants: 手順 1、 1の画像 1
    • To make the process of tailoring your pants easier, use a second pair of pants that already has the desired length as an outline.
    • Place the pants with the length you want on top of the pants that you will be tailoring.
  2. How to Tailor Your Pants: 手順 2、 1の画像 1
    • Measure the length you want to cut off with your fingers.
    • The amount of fingers you use may vary depending on the length you want to cut off.
  3. How to Tailor Your Pants: 手順 3、 1の画像 1
    • Pin your pants at the length you want to cut off.
    • An alternative option to pinning your pants is marking the length with a pencil.
  4. How to Tailor Your Pants: 手順 4、 1の画像 1
    • Cut along the pins.
    • Cut along the pencil mark if you chose this option instead.
  5. How to Tailor Your Pants: 手順 5、 1の画像 1
    • Fold the pants so that the seam is on the inside. Next, sew along the folded edge with a sewing machine.
    • Pin the pants to keep the fold in place and to make sewing easier.
  6. How to Tailor Your Pants: 手順 6、 1の画像 1
    • Check to make sure your pants are now your desired length.
  7. How to Tailor Your Pants: 手順 7、 1の画像 1
    • If you have achieved your desired length then you are finished!
終わりに
You finally finished sewing your jeans so now you can enjoy wearing them :)
作成者
4人の作成者と共同で作成されました。
Exlexis Archouletta
メンバー登録日: 10/20/20
133 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team S12-G14, Harris Fall 2020 CSU Los Angeles, Team S12-G14, Harris Fall 2020人のメンバー
CSULA-HARRIS-F20S12G14
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 20
今までの合計 547
