はじめに
This guide will show you how to stabilize the motherboard of the Logitech Harmony 900 by placing a shim on the CPU. This guide is designed to solve the problem of device not starting due to bad CPU connections.
必要な工具と部品
Press the oval shaped button on the lower back of the remote to release the battery cover.
While pressing the button, remove the cover.
この手順で使用する道具:Tweezers$4.99
Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
Fold a small piece of paper several times until you have a shim about the size of a penny.
5 の人々がこのガイドを完成させました。
3件のガイドコメント
Bought this remote at Goodwill for $15. Repair went flawlessly in 10 minutes. THANKS!!!!!!
Hello Tyler,
If you are going to place the shims on the top of cpu, why you have to remove the motherboard completely with screws and ribbon cable from the remote?
Thanks
Sweet fix thought mine had died
Sean Garbe - 返信
