メインコンテンツにスキップ
How to Stabilize the Logitech Harmony 900 Motherboard
必要な工具と部品
  1. How to Stabilize the Logitech Harmony 900 Motherboard, Battery: 手順 1、 2の画像 1 How to Stabilize the Logitech Harmony 900 Motherboard, Battery: 手順 1、 2の画像 2
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
  2. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 2、 2の画像 1 How to Stabilize the Logitech Harmony 900 Motherboard: 手順 2、 2の画像 2
    • Push the battery in, pull it up, and slide it out.
  3. How to Stabilize the Logitech Harmony 900 Motherboard, Motherboard: 手順 3、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
  4. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 4、 2の画像 1 How to Stabilize the Logitech Harmony 900 Motherboard: 手順 4、 2の画像 2
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
  5. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 5、 1の画像 1
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
  6. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 6、 2の画像 1 How to Stabilize the Logitech Harmony 900 Motherboard: 手順 6、 2の画像 2
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
  7. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 7、 2の画像 1 How to Stabilize the Logitech Harmony 900 Motherboard: 手順 7、 2の画像 2
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
  8. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 8、 2の画像 1 How to Stabilize the Logitech Harmony 900 Motherboard: 手順 8、 2の画像 2
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
  9. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 9、 2の画像 1 How to Stabilize the Logitech Harmony 900 Motherboard: 手順 9、 2の画像 2
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
  10. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 10、 1の画像 1
    • Using your hands, carefully separate the motherboard from the rest of the remote.
  11. How to Stabilize the Logitech Harmony 900 Motherboard, How to Stabilize the Logitech Harmony 900 Motherboard: 手順 11、 1の画像 1
    • Fold a small piece of paper several times until you have a shim about the size of a penny.
  12. How to Stabilize the Logitech Harmony 900 Motherboard: 手順 12、 2の画像 1 How to Stabilize the Logitech Harmony 900 Motherboard: 手順 12、 2の画像 2
    • Place the shim on the CPU, which is the top leftmost black box on the motherboard.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Tyler Hanks
メンバー登録日: 09/25/17
442 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S4-G5, Eyestone Fall 2017 USF Tampa, Team S4-G5, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S4G5
4 メンバー
4のガイドは作成済み
3件のガイドコメント
Bought this remote at Goodwill for $15. Repair went flawlessly in 10 minutes. THANKS!!!!!!
Scott Casey - 返信
Hello Tyler,
If you are going to place the shims on the top of cpu, why you have to remove the motherboard completely with screws and ribbon cable from the remote?
Thanks
Daniel Leprince - 返信
Sweet fix thought mine had died
Sean Garbe - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 17
今までの合計 1,394
