メインコンテンツにスキップ
How to Shrink a Tennis Racket Grip
必要な工具と部品
  1. How to Shrink a Tennis Racket Grip, Remove Grip Tape: 手順 1、 1の画像 1
    • Pull the tape until it comes off of the grip.
    • Use a sharp object to cut it off if needed.
  2. How to Shrink a Tennis Racket Grip, Remove the Overgrip: 手順 2、 2の画像 1 How to Shrink a Tennis Racket Grip, Remove the Overgrip: 手順 2、 2の画像 2
    • If your racket does not have an overgrip on it, then skip this step.
    • There is a good chance it is sticky.
  3. How to Shrink a Tennis Racket Grip, Put the Overgrip at the Bottom of the Handle: 手順 3、 1の画像 1
    • Attach the smaller end of the new overgrip to the bottom of the handle.
    • Wrap the overgrip around the handle, parallel to the bottom of the grip.
  4. How to Shrink a Tennis Racket Grip, Wrap the Overgrip around the Handle: 手順 4、 1の画像 1
    • Pull the grip tightly, leaving little to no open areas between the different parts of the overgrip.
    • Leave a little overlap between each row of your grip.
    • Most of your overgrip should cover the handle instead of a lower row of overgrip.
    • Make each row as close to the same size as possible.
  5. How to Shrink a Tennis Racket Grip, Put on the Tape: 手順 5、 2の画像 1 How to Shrink a Tennis Racket Grip, Put on the Tape: 手順 5、 2の画像 2
    • It should tie the end of the grip to the rest of the racket.
    • I did not cut the end of the overgrip with scissors. If you want the grip to fit better, cut the end of the overgrip off at a 45 degree angle.
終わりに
If you decide that you want to go back to the racket grip's original size, then you need to remove the overgrip and put on a replacement grip.
作成者
2人の作成者と共同で作成されました。
Jim Watkins
メンバー登録日: 10/01/23
133 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 266
