メインコンテンツにスキップ
How to Shorten the Length of Pyjama Pants
必要な工具と部品
  1. How to Shorten the Length of Pyjama Pants, How to Shorten the Length of Pyjama Pants: 手順 1、 1の画像 1
    • Press the pyjamas with an iron to ensure there are no creases.
    • Be careful while using the iron to avoid any burns.
  2. How to Shorten the Length of Pyjama Pants: 手順 2、 1の画像 1
    • Take some fabric chalk and measuring tape, then measure the desired length and then make marks on each leg as follows:
    • The left line indicates the desired length line.
    • The right line indicates the one inch line for the new hem you'll be creating.
  3. How to Shorten the Length of Pyjama Pants: 手順 3、 1の画像 1
    • Use scissors to remove fabric below the lower one inch line created from the chalk marks to shorten the length. Do this for each pant leg.
  4. How to Shorten the Length of Pyjama Pants: 手順 4、 3の画像 1 How to Shorten the Length of Pyjama Pants: 手順 4、 3の画像 2 How to Shorten the Length of Pyjama Pants: 手順 4、 3の画像 3
    • Take a needle and about 30 inches of thread and put the thread through the needle, then immediately tie the thread off.
    • Be careful with the needle as minor injury may occur if not handled carefully.
  5. How to Shorten the Length of Pyjama Pants: 手順 5、 3の画像 1 How to Shorten the Length of Pyjama Pants: 手順 5、 3の画像 2 How to Shorten the Length of Pyjama Pants: 手順 5、 3の画像 3
    • Fold the pyjama from the one inch extra line so the desired length is achieved, and then hem with the needle.
    • The needle needs to pass through both layers of the folded fabric to start the hemming process.
    • Do this for each pyjama leg.
    • There should be at least 45 stitches on each pyjama leg.
  6. How to Shorten the Length of Pyjama Pants: 手順 6、 3の画像 1 How to Shorten the Length of Pyjama Pants: 手順 6、 3の画像 2 How to Shorten the Length of Pyjama Pants: 手順 6、 3の画像 3
    • At the end of the hem, take the needle through the thread three times to secure the stitch.
終わりに
Congratulations; you did it!
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Aisha Freed
メンバー登録日: 07/03/22
211 ポイント
1ガイドが承認済み
チーム
York University, Team M-8, Allen Summer 2022 York University, Team M-8, Allen Summer 2022人のメンバー
YORK-ALLEN-SU22SMG8
1 メンバー
1のガイドは作成済み
コメント 1 件
It is a great and clear repair guide! You shot good photos for every step. Your actions were all well-captured in the photos by using the flip-book style. Properly use of markup also made the guide easier to understand. Also, all the instructions described the actions clearly so it is easy to follow.
Great work!
Cheuk Wai Chan - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 49
過去 30 日: 177
今までの合計 2,072
