メインコンテンツにスキップ
How to Shorten and Hem Sleeves on a Shirt by Hand
必要な工具と部品
  1. How to Shorten and Hem Sleeves on a Shirt by Hand, How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 1、 2の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand, How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 1、 2の画像 2
    • Measure out the desired length of the sleeve.
    • Leave at least 1 inch of fabric because you will fold back and hem the sleeves.
  2. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 2、 2の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 2、 2の画像 2
    • Cut the shirt sleeve to the desired length.
  3. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 3、 2の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 3、 2の画像 2
    • Turn the shirt inside out.
    • Roll up the shirt sleeve by 1 inch.
  4. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 4、 2の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 4、 2の画像 2
    • Measure the shirt sleeve to make sure it is even in the front and back of the sleeve cuff.
    • Use sewing pins to secure the sleeve cuff in place.
    • Sewing pins are sharp so be careful when using them. We recommend placing the pins in the middle or lower part of the cuff as to not get in the way of sewing.
  5. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 5、 2の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 5、 2の画像 2
    • Measure about 1/4 of an inch from the top of the sleeve cuff.
    • Use this as a guiding line to make your stitches appear straight.
  6. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 6、 1の画像 1
    • Loop the thread through your sewing needle and tie it together.
  7. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 7、 2の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 7、 2の画像 2
    • Underneath the sleeve cuff, push your needle through the sleeve.
  8. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 8、 3の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 8、 3の画像 2 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 8、 3の画像 3
  9. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 9、 3の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 9、 3の画像 2 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 9、 3の画像 3
    • In the space above the sleeve cuff, make a right-to-left stitch.
    • Then push the needle right-to-left into the sleeve cuff where you made the guide lines.
    • This will create a zigzag pattern in the shape of an upside down "V."
  10. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 10、 3の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 10、 3の画像 2 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 10、 3の画像 3
    • Repeat the steps to sew the entire sleeve cuff.
  11. How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 11、 3の画像 1 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 11、 3の画像 2 How to Shorten and Hem Sleeves on a Shirt by Hand: 手順 11、 3の画像 3
    • To end the catch stitch, push your needle into the starting stitch and make a small knot.
    • Make a few more knots to secure the thread.
    • Cut the thread with scissors.
    • Remove the sewing pins.
    • Turn the shirt inside out again and you're done!
ゴール
作成者
1人の作成者と共同作成されました。
Katie Nguyen
メンバー登録日: 10/03/22
202 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-11, Friess Fall 2022 University of North Texas, Team 1-11, Friess Fall 2022人のメンバー
UNT-FRIESS-F22S1G11
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 73
過去 30 日: 399
今までの合計 5,653
