メインコンテンツにスキップ
How to Sharpen Troy-Bilt TB110 Lawnmower Blades
必要な工具と部品
  1. How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 1、 2の画像 1 How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 1、 2の画像 2
    • Disconnect the spark plug wire.
    • This step is critical to avoid an accidental startup since we are working on the blade.
  2. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 2、 2の画像 1 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 2、 2の画像 2
    • Put saran wrap on the inside of the gas cap.
    • This is done to prevent gas from spilling out when we turn over the lawnmower.
  3. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 3、 1の画像 1
    • Turn the lawn mower over on its side.
  4. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 4、 2の画像 1 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 4、 2の画像 2
    • Use a 5/8 ratchet or wrench to remove the bolt. Then remove the blade.
    • Note how the blade is oriented on the lawn mower for reassembly.
    • Do not grab it from the sharp parts of the blade.
  5. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 5、 1の画像 1
    • Clean the blade with a scraper or a wire brush to remove grass residue .
  6. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 6、 1の画像 1
    • Secure the blade in a vice.
  7. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 7、 2の画像 1 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 7、 2の画像 2
    • Sharpen the blade with a file or with a grinder. Follow the angle that is already established and move the file along until the edge becomes sharp.
    • Be carful when checking for sharpness. You can very gently run your finger along the edge to check.
    • The blade does not need to be as sharp as a razor blade. Try to make it as sharp as pair of scissors. Check the lawnmower for specific details.
  8. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 8、 2の画像 1 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 8、 2の画像 2
    • Put the blade back onto the lawn mower and screw the bolt back on while safely securing the blade.
    • Again be careful not to hold the blade by the sharp edges.
  9. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 9、 2の画像 1 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 手順 9、 2の画像 2
    • Flip the lawn mower back to the upright position and remove the saran wrap from the gas cap.
    • Plug the spark plug wire in until you hear a click.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Andrew DePari
メンバー登録日: 03/24/21
193 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S1-G7, O'Connell Spring 2021 UMass Dartmouth, Team S1-G7, O'Connell Spring 2021人のメンバー
UMASSD-O'CONNELL-S21S1G7
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 36
今までの合計 1,099
