メインコンテンツにスキップ
How to Sew a Hole and reattach zippers to a purse
必要な工具と部品
  1. How to Sew a Hole and reattach zippers to a purse, Hole and Zippers: 手順 1、 1の画像 1
    • Locate the hole.
    • It’s important to analyze the area and make sure you have enough thread to cover the area; more is always better.
  2. How to Sew a Hole and reattach zippers to a purse: 手順 2、 1の画像 1
    • Get a needle and thread ready to sew and make a knot at the end of the thread.
  3. How to Sew a Hole and reattach zippers to a purse: 手順 3、 2の画像 1 How to Sew a Hole and reattach zippers to a purse: 手順 3、 2の画像 2
    • Sew the hole together.
    • Notice that the fabric looks smooth and straight, this is from folding the frayed parts of the fabric inward to make the sewing process easier.
    • Make sure to end your sewing session with a secured knot, and cut off excess thread.
  4. How to Sew a Hole and reattach zippers to a purse: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use tweezers to grab one side of the opened coil.
  5. How to Sew a Hole and reattach zippers to a purse: 手順 5、 1の画像 1
    • Locate the detached zipper slider and turn it backwards.
    • This is done while still holding one side of the opened coil.
  6. How to Sew a Hole and reattach zippers to a purse: 手順 6、 1の画像 1
    • Place one side of the coil inside the zipper slider just a little using tweezers.
  7. How to Sew a Hole and reattach zippers to a purse: 手順 7、 2の画像 1 How to Sew a Hole and reattach zippers to a purse: 手順 7、 2の画像 2
    • Grab the other side of the opened coils and place that side inside the zipper slider.
    • Make sure that each of the coils are placed evenly inside the slider.
  8. How to Sew a Hole and reattach zippers to a purse: 手順 8、 2の画像 1 How to Sew a Hole and reattach zippers to a purse: 手順 8、 2の画像 2
    • Once both coils are even, using the zipper “Pull”, slowly slide the “Pull” closing it.
  9. How to Sew a Hole and reattach zippers to a purse: 手順 9、 3の画像 1 How to Sew a Hole and reattach zippers to a purse: 手順 9、 3の画像 2 How to Sew a Hole and reattach zippers to a purse: 手順 9、 3の画像 3
    • Repeat steps 4 to 9 for the other zipper wrapping up the coil process and being able to close both zippers.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
ReNieka Perry
メンバー登録日: 01/21/18
223 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018人のメンバー
USFSM-STEWART-S18S1G1
15 メンバー
26のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 77
今までの合計 1,992
