はじめに
Knowing how to sew a buttonhole by hand is a handy skill to have if you don't own a sewing machine and don't want to pay a tailor. If you can sew a basic straight stitch, you can make a buttonhole. Pull that old favorite shirt out of the discard bag and give it a new life. Your small but mighty needle will help you keep the clothes in your closet instead of in the landfill.
必要な工具と部品
Place your button where you want the buttonhhole.
Use a chalk marker or washable fabric marker to make a vertical line just to the right of the button.
Use your marker to make a vertical line just to the left of the button.
Working from right to left, continue sewing small, tight, vertical stitches along the top side of the buttonhole slit.
When you get to the left edge, make a row of small horizontal stitches around that end, until you arrive back where you began.
Push your needle through to the back and tie it off with a knot.
ある他の人がこのガイドを完成しました。
