メインコンテンツにスキップ
How to Secure a Hook and Eye Fastener Properly
必要な工具と部品
  1. How to Secure a Hook and Eye Fastener Properly, How to Secure a Hook and Eye Fastener Properly: 手順 1、 1の画像 1
    • Cut about 28 inches of thread and fold it in half which would be one loop and the two ends together.
    • Then thread the two ends through the eye of the needle.
  2. How to Secure a Hook and Eye Fastener Properly: 手順 2、 2の画像 1 How to Secure a Hook and Eye Fastener Properly: 手順 2、 2の画像 2
    • Slide the needle down the thread until you reach about two inches from the loop.
    • Position the needle between the loop and pull through.
    • This will create a knot at the base of the needle which will make the thread less tangled.
    • Next, pull on both ends of the thread to make them equal length before tying a knot.
  3. How to Secure a Hook and Eye Fastener Properly: 手順 3、 1の画像 1
    • First, position the hook above the zipper and on the inside fabric, about 3mm from the edge.
  4. How to Secure a Hook and Eye Fastener Properly: 手順 4、 2の画像 1 How to Secure a Hook and Eye Fastener Properly: 手順 4、 2の画像 2
    • Remove the hook and start by sewing a stitch where your hook was.
    • Then trim the extra thread close to the knot.
  5. How to Secure a Hook and Eye Fastener Properly: 手順 5、 2の画像 1 How to Secure a Hook and Eye Fastener Properly: 手順 5、 2の画像 2
    • Sew on top of the knot three times to make sure it is secure.
    • Position the hook on top of the stitch.
    • Anchor the front part of the hook down by sewing over the bottom edge of the hook three times.
  6. How to Secure a Hook and Eye Fastener Properly: 手順 6、 1の画像 1
    • Then poke the needle underneath the fabric and bring it up in one of the holes.
  7. How to Secure a Hook and Eye Fastener Properly: 手順 7、 2の画像 1 How to Secure a Hook and Eye Fastener Properly: 手順 7、 2の画像 2
    • Now hold the other eye of the hook in place.
    • The needle is going to go in from the outside of the wired edge to inside the circle and pull that through till you get a small loop.
    • After that push, the needle through that loop and pull which create a small knot.
    • Now repeat this stitch two more times.
  8. How to Secure a Hook and Eye Fastener Properly: 手順 8、 1の画像 1
    • Then take the needle into the other hole, coming up in the center.
  9. How to Secure a Hook and Eye Fastener Properly: 手順 9、 1の画像 1
    • Then repeat step 7 for this hole.
  10. How to Secure a Hook and Eye Fastener Properly: 手順 10、 1の画像 1
    • After this, tie a knot.
    • Then cut the thread and tie a knot at the end of the thread.
  11. How to Secure a Hook and Eye Fastener Properly: 手順 11、 1の画像 1
    • To position the eyes, place the hook and eyes together and line up the fabric so the edges match.
  12. How to Secure a Hook and Eye Fastener Properly: 手順 12、 2の画像 1 How to Secure a Hook and Eye Fastener Properly: 手順 12、 2の画像 2
    • Hold it in place with your fingers. Start by stitching across the wire and trim the tail near the knot.
    • Sew on top of the knot and the wire three times to make sure it is secure.
    • Making sure you come out from the middle of the eyes.
  13. How to Secure a Hook and Eye Fastener Properly: 手順 13、 1の画像 1
    • After this, repeat step 7.
  14. How to Secure a Hook and Eye Fastener Properly: 手順 14、 2の画像 1 How to Secure a Hook and Eye Fastener Properly: 手順 14、 2の画像 2
    • Then repeat step 8 and 9.
    • It should look like this at the end.
ゴール
作成者
1人の作成者と共同作成されました。
Cecilia
メンバー登録日: 05/10/21
229 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G29, O'Regan Summer 2021 York University, Team S1-G29, O'Regan Summer 2021人のメンバー
YORK-O'REGAN-SU21S1G29
1 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 86
今までの合計 2,299
