この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Knowing how to rip a seam is essential for basic sewing and clothing repair. Whether you want to make alterations, replace a zipper, or fix a sewing mishap, ripping the seam properly will make the changes nearly invisible.
必要な工具と部品
Slip the sharp end of the seam ripper through a single stitch in the seam you want to remove.
Slide the seam ripper forward. Bring the thread into the crux of the fork and onto the blade.
Gently push the seam ripper forward again, cutting the thread.
Continue working, stitch by stitch, until the seam has been removed. Take your time, being careful not to damage the fabric.
Remove all of the loose threads from the ripped seam to prevent tangling when you resew the seam.
6 の人々がこのガイドを完成させました。
